pgRouting logo
pgRouting Quickstart
pgRouting is an extension that adds routing and other network analysis functionality to PostGIS/PostgreSQL databases.
This Quick Start describes how to enable pgrouting in a PostgreSQL database, load data with osm2pgrouting, and run a basic shortest path query with the sample test data.
Enabling pgRouting in a database
In this example we will create a database called city_routing and enable pgRouting in the database.
  • Open a Applications ‣ Accessories ‣ Terminal window and open up psql:
(psql is the commandline tool packaged with PostgreSQL)
psql
At psql prompt type:
CREATE DATABASE city_routing;
\connect city_routing;
CREATE EXTENSION postgis;
CREATE EXTENSION pgrouting;
If you are running PostgreSQL 9.6+, you can skip the postgis line and do CREATE EXTENSION pgrouting CASCADE;
You can verify your installation by running this:
SELECT  * FROM pgr_version();
 version |       tag       |  hash   | branch | boost
 2.2.2   | pgrouting-2.2.2 | 7141904 | master | 1.59.0
(1 row)
Your version should be 2.1.0 or higher to use examples in this quickstart.
Loading OSM data with osm2pgrouting
osm2pgorouting is a command-line tool for loading .osm files into pgRouting compatible format. Here is how you use osm2pgrouting version 2.1.0+
First verify version of osm2pgrouting you have installed. Should read 2.1 or higher.
osm2pgrouting --version
Output shows:
This is osm2pgrouting Version 2.1
Now load the data from osm file
cd
bzcat data/osm/feature_city.osm.bz2 > /tmp/feature_city.osm
osm2pgrouting -f /tmp/feature_city.osm -h localhost -U user -d city_routing -p 5432 -W user --conf=/usr/share/osm2pgrouting/mapconfig_for_cars.xml
rm /tmp/feature_city.osm
Output should be something like:
Opening data file: feature_city.osm
    Parsing data
Spliting ways
Dropping tables...
NOTICE:  table "ways" does not exist, skipping
NOTICE:  table "ways_vertices_pgr" does not exist, skipping
NOTICE:  table "relations_ways" does not exist, skipping
Creating tables...
Creating 'ways_vertices_pgr': OK
   Adding Geometry: Creating 'ways': OK
   Adding Geometry: Creating 'relations_ways': OK
Creating 'osm_nodes': OK
   Adding Geometry: Creating 'osm_relations': OK
Creating 'osm_way_tags': OK
Creating 'osm_way_types': OK
Creating 'osm_way_classes': OK
Adding auxiliary tables to database...
    Processing 1 way types:  Inserted 1 way types
    Processing way's classes:  Inserted 16 way's classes
    Processing way's relations:  Inserted: 83874way's relations
    Processing way's tags:  Inserted 10455 way's tags
    Processing 10455 ways:
Vertices inserted 9165    Ways inserted: 10455
Creating topology...
size of streets: 4904
size of splitted ways : 10455
Execution started at: Tue Jun 21 17:57:57 2016
Execution ended at:   Tue Jun 21 17:58:02 2016
Elapsed time: 5.084 Seconds.
User CPU time: -> 5.084 seconds
Running pgRouting
  • Open a Applications ‣ Accessories ‣ Terminal window and connect to the city_routing database:
psql -U postgres city_routing
  • Type \d will list you all available tables:
                    List of relations
 Schema |           Name           |   Type   |  Owner
 public | geography_columns        | view     | postgres
 public | geometry_columns         | view     | postgres
 public | osm_nodes                | table    | postgres
 public | osm_nodes_node_id_seq    | sequence | postgres
 public | osm_relations            | table    | postgres
 public | osm_way_classes          | table    | postgres
 public | osm_way_tags             | table    | postgres
 public | osm_way_types            | table    | postgres
 public | raster_columns           | view     | postgres
 public | raster_overviews         | view     | postgres
 public | relations_ways           | table    | postgres
 public | spatial_ref_sys          | table    | postgres
 public | ways                     | table    | postgres
 public | ways_gid_seq             | sequence | postgres
 public | ways_vertices_pgr        | table    | postgres
 public | ways_vertices_pgr_id_seq | sequence | postgres
(16 rows)
  • Run the Dijkstra shortest path function assuming undirected travel:
SELECT seq, node, edge, cost
        FROM pgr_dijkstra('
                SELECT gid as id, source, target,
                        length as cost FROM ways',
                100, 600, false
 seq | node | edge  |         cost
   1 |  100 |   148 |  0.000106201177015572
   2 | 3603 |  4118 |  0.000171096610136435
   3 | 8284 |  9429 |  0.000101401380664492
  37 | 3461 |  3964 |   0.00121559903339768
  38 | 1761 |  2013 |   0.00307553090376563
  39 | 5981 |  6801 |  0.000158813884783759
  40 |  600 |    -1 |                     0
(40 rows)
pgr_dijkstra also supports bigints for nodes and edges, and osm2pgrouting loads the osm_ids as well, so you could alternatively use the osm_id instead of the autogenerated source and targets for nodes. To look up the corresponding osm_ids for our nodes, we would use this query:
SELECT id, osm_id
        FROM ways_vertices_pgr where id IN( 100, 600);
Which outputs:
 id  |   osm_id
 100 | 1896068597
 600 |   31369798
(2 rows)
To do so you would change your query to below:
FROM pgr_dijkstra('
        SELECT gid as id, source_osm AS source, target_osm AS target,
        1896068597, 31369798, false
Note: the SQL statement must always have field names id, source, target, and cost. Since we are using fields source_osm and target_osm, we need to alias them so resulting pgr_dijkstra query columns are named source and target
Output is:
   1 | 1896068597 |   148 |  0.000106201177015572
   2 |  471372588 |  4118 |  0.000171096610136435
   3 |  471372583 |  9429 |  0.000101401380664492
  37 | 1370351630 |  3964 |   0.00121559903339768
  38 |   30812815 |  2013 |   0.00307553090376563
  39 | 3214028631 |  6801 |  0.000158813884783759
  40 |   31369798 |    -1 |                     0
(40 rows)
Since we are still using autogenerated edge ids, our edge numbers are the same as our previous query, but the nodes are the osm node ids.
The benefit of using the osm_ids instead of the auto-generated ids is that your results will be consistent between different databases if they share a common set of osm ids. Not all pgRouting functions have been changed to use bigints, so osm_ids can’t be used with all functions.
  • To output the route geometry, link the result with the road geometries:
SELECT seq, edge, rpad(b.the_geom::text,60,' ') AS "the_geom (truncated)"
        FROM pgr_dijkstra('
                100, 600, false
        ) a INNER JOIN ways b ON (a.edge = b.gid) ORDER BY seq;
 seq | edge  |                     the_geom (truncated)
   1 |   148 | 0102000020E61000000200000035BEE5A03A641C40BC98C1734A5E4940F4
   2 |  4118 | 0102000020E610000002000000F4CE577F3A641C402B5CA0EE4D5E494058
   3 |  9429 | 0102000020E61000000200000058BCA2A53C641C40C3503D88535E4940F5
  36 |  6538 | 0102000020E6100000020000002999F7938C6F1C409DD843FB585D49405C
  37 |  3964 | 0102000020E6100000020000005CAE7E6C926F1C40E55C2FF2575D494088
  38 |  2013 | 0102000020E6100000020000008849B89047701C406DF7BC2C375D4940E8
  39 |  6801 | 0102000020E610000002000000E82E89B322721C40A85890C1E55C494059
(39 rows)
  • You can view the routes using a graphical tool
such as OpenJump or the QGIS DbManager extension.
To use the DbManager extension of QGIS open up QGIS then go to Go to Database -> DB Manager -> DB Manager. Select the SQL Window icon and cut and paste the above pgRouting Query.
  • Run the Dijkstra shortest path function with considering direction.
In the previous examples, we assumed streets have equal cost in both directions. For cases where you have one ways or different speed limits on either lane, cost going on one direction of a road, may be different than going the other way. For these cases you need to add an additional column to your query reverse_cost
        FROM pgr_dijkstra('
                        cost_s As cost, reverse_cost_s AS reverse_cost FROM ways',
                100, 600, true
  • With \q command leave the PostgreSQL shell.
What next?
