PyWPS Quickstart¶
PyWPS is an OGC WPS (Web Processing Service 1.0.0) server implementation written in Python.
PyWPS is installed by default on OSGeo-Live. This Quickstart describes how to:
- test the PyWPS installation
- configure the PyWPS instance
- create and deploy processes in PyWPS
- perform
GetCapabilities
,DescribeProcess
andExecute
operations
Tester Application¶
To run the PyWPS tester, use the PyWPS launcher from the Web Services group. This opens
Firefox displaying http://localhost/pywps/wps.py?service=WPS&version=1.0.0&request=GetCapabilities
. The
XML response provides an overview of the Service (title, abstract, keywords), the Service
point of contact as well as a list of processes supported by the PyWPS installation.
Lets select the ultamitequestionprocess
process from the list and
display its description by calling the DescribeProcess operation. In Firefox,
enter the following URL: http://localhost/pywps/wps.py?service=WPS&version=1.0.0&request=DescribeProcess&identifier=ultimatequestionprocess
You should see WPS DescribeProcess response document. The XML response provides a description
of what the process does as well as specifics (name, type) on the inputs and outputs. We can
see in the above response that the ultimatequestionprocess
process (according to its description) is able
to provide the Answer to Life, the Universe and Everything, takes no inputs and provides
a single integer output.
Now let’s run the ultimatequestionprocess
process on the server. In Firefox,
enter the following URL: http://localhost/pywps/wps.py?service=WPS&version=1.0.0&request=Execute&identifier=ultimatequestionprocess
Here we can see the answer to life, universe and everyting is 42.
Configuration¶
You can configure the PyWPS instance in the /etc/pywps/pywps-wsgi.cfg configuration file. More information on the configuration option can be found in the standard documentation
Processes¶
You can find some more example processes in the /etc/pywps/processes directory. Every process is usually stored in separate file and is represented by a Python class, with constructor and execute() methods:
# Example of PyWPS process (shorten)
from pywps.Process import WPSProcess
class Process(WPSProcess):
def __init__(self):
WPSProcess.__init__(self,
identifier="ultimatequestionprocess", # the same as the file name
def execute(self):
import time
self.status.set("Preparing....", 0)
for i in xrange(1, 11):
time.sleep(2)
self.status.set("Thinking.....", i*10)
# final answer
self.Answer.setValue("42")
Directory of your process deployment is configured within the PYWPS_PROCESSES environment variable.
Things to Try¶
Here are some additional challenges for you to try:
- Try updating some of the configuration values to see how they are updated in the
GetCapabilities
requess - Try running the
DescribeProcess
andExecute
requests against other processes
What’s Next¶
PyWPS gives you the freedom and flexibility to write your own Python processes and expose them accordingly.
Official documentation
For further information on PyWPS configuration and the API, consult the documentation on the PyWPS website.
Tutorial
Try out the course, which includes setting up an OpenLayers based web client.
