Sahana Quickstart¶
Getting Started¶
Sahana Eden is already installed and configured when you start OSGeo-Live. To access Sahana Eden click on the click here. By default, you will have view-only rights to access the data. If you wish to create new records, or edit existing records, you will need to be logged in as a user - use the following credentials to get started.
. If you started it earlier you can simply- E-mail: admin
- Password: admin
If you have entered example crowd-sourced data in Ushahidi, then you can access that information in Sahana Eden by following this link.
You will find it has already been configured to access the map data and map servers that are part of OSGeo-Live. Sahana Eden can utilise OpenStreetMap as an underlying map layer in the map viewing client. Sahana Eden supports a wide range of OpenStreetMap services.
Development¶
Sahana Eden is always looking for more developers to join and contribute to our project. The primary development platform is the Python programming language and the web2py Enterprise Web Framework. We additionally are looking for contributors with skills in mapping, jquery and javascript.
- Want to help Develop Sahana Eden?
- Ticket System - for reporting problems
