OpenLayers 快速入门
OpenLayers 实例
  通过学习示例可以快速掌握 OpenLayers 的使用。一些示例安装在 Live http://localhost/openlayers/examples
第一个地图服务
  OpenLayers API 服务涉及两个重要的基本概念,为 ‘Map 地图’ 和 ‘Layer 图层’ 。一个 OpenLayers 地图保存了包括默认投影系统、空间范围、度量单位、    stores information about the default projection, extents, units, and so on of the map. Inside the map, data is displayed via ‘Layer’s. A Layer is a data source – information about how OpenLayers should request data and display it.
Crafting HTML
Building an OpenLayers viewer requires crafting HTML in which your viewer will be seen. OpenLayers supports putting a map inside of any block level element – this means that it can be used to put a map in almost any HTML element on your page.
In addition to a single block level element, it is also required to include a script tag which includes the OpenLayers library to the page.
<html>
<head>
  <title>OpenLayers Example</title>
    <script src="http://localhost/openlayers/OpenLayers.js"></script>
    </head>
    <body>
      <div style="width:100%; height:100%" id="map"></div>
    </body>
</html>
Ex. 1: Creating your first HTML Page
Creating the Map Viewer
In order to create the viewer, you must first create a map. The OpenLayers.Map constructor requires one argument: This argument must either be an HTML Element, or the ID of an HTML element. This is the element in which the map will be placed.
var map = new OpenLayers.Map('map');
Ex. 2: Map Constructor
The next step to creating a viewer is to add a layer to the Map. OpenLayers supports many different data sources, from WMS to Yahoo! Maps to WorldWind. In this example, the WMS layer is used. The WMS layer is an example provided by MetaCarta.
var wms = new OpenLayers.Layer.WMS(
  "WMS",
  "http://localhost/cgi-bin/qgis_mapserv.fcgi",
  'map': '/usr/local/share/qgis/QGIS-NaturalEarth-Example.qgs',
  'layers':'HYP_50M_SR_W,10m_lakes,10m_rivers_lake_centerline'} );
map.addLayer(wms);
Ex. 3: Layer Constructor
The first parameter in this constructor is the name of the layer, which is used for some display purposes. The second argument is the URL of the WMS server. The third argument is an object containing the parameters to be appended to the WMS request.
Finally, in order to display the map, you must set a center and zoom level. In order to zoom to fit the map into the window, you can use the zoomToMaxExtent function, which will zoom as close as possible while still fitting the full extents within the window.
Putting it All Together
The following code block puts all the pieces together to create an OpenLayers viewer.
<html>
<head>
    </head>
    <body>
      <script defer="defer" type="text/javascript">
          "WMS",
        map.addLayer(wms);
        map.zoomToMaxExtent();
      </script>
</body>
</html>
Ex. 4: Full HTML and Javascript for simple WMS browser
Adding an Overlay WMS
WMS layers have the capability to be overlaid on top of other WMS layers in the same projection. There are several ways to mark a layer as an overlay, rather than a base layer. With WMS, the best way to do this is by setting the ‘transparent’ parameter to ‘true’. The example here uses a political borders WMS to demonstrate overlaying a transparent WMS.
var twms = new OpenLayers.Layer.WMS( "World Map",
    "http://world.freemap.in/cgi-bin/mapserv?",
    { map: '/www/freemap.in/world/map/factbooktrans.map',
      transparent: 'true', layers: 'factbook'}
map.addLayer(twms);
Ex. 5: How to add a transparent WMS overlay to your map.
Using the transparent: ‘true’ parameter sets two flags automatically:
  • format parameter. The format option of the WMS layer is set to image/png if the browser supports transparent PNG images. (This is all browsers except for Internet Explorer 6.) In Internet Explorer 6, this will instead be set to image/gif.
  • isBaseLayer option. The isBaseLayer option controls whether the layer can be displayed at the same time as other layers. This option defaults to false for the WMS layer, but setting transparent to true changes it to true by default.
Adding a Vector Marker to the Map
To add a single marker at a latitude and longitude to the map, you can use a Vector Layer to add an overlay.
var vectorLayer = new OpenLayers.Layer.Vector("Overlay");
var feature = new OpenLayers.Feature.Vector(
 new OpenLayers.Geometry.Point(-71, 42),
 {some:'data'},
 {externalGraphic: 'img/marker.png', graphicHeight: 21, graphicWidth: 16});
vectorLayer.addFeatures(feature);
map.addLayer(vectorLayer);
This is a simple demonstration – more information is available on overlays, how to interact with them, and how to control and style them via the OpenLayers documentation on openlayers.org.
