Command Line basics¶
When you work with GNU/Linux Operating Systems such as OSGeoLive, Ubuntu, etc., it is good to know how to work on the command line.
Don’t worry. It is not difficult to learn and you will discover that it is fun and very powerful.
In this quickstart you will learn some basic commands.
The following commands run from within a Terminal Emulator window.
Start a Terminal Emulator (QTerminal currently) from the Applications menu in the System Tools section. This gives you a Unix shell command prompt.
Contents
- Where am I?
- How to navigate in the file system?
- Create a directory
- How to create a new file
- Show me what is in a directory
- Copy files and directories
- Who is sudo?
- Search and install programs
- Services
- How to edit files
- Owner and access rights
- Change the owner with chown
- Change access rights with chmod
- Things to try
- What next?
Where am I?¶
pwd shows the path of your current location.
pwd
/home/user
Tip
You can ask all commands for help and get information on how they can be used and find out about additional options.
pwd --help
pwd: pwd [-LP]
Print the name of the current working directory.
Options:
-L print the value of $PWD if it names the current working
directory
-P print the physical directory, without any symbolic links
By default, `pwd' behaves as if `-L' were specified.
Exit Status:
Returns 0 unless an invalid option is given or the current directory cannot be read.
Create a directory¶
You have write access in your user-directory. You can create files and directories there. Next we will create a directory for some command line tests.
cd ~
mkdir demo - creates the directory demo
cd demo
Tip
You have a command history. You can navigate in the history with the arrow up and down key.
How to create a new file¶
touch creates a new empty file.
cd ~/demo
touch hello.txt
Tip
You can pipe the information from a command to a file i.e. the command history. history displays the command history. With the following command it can be saved in a file.
history > history.txt
Show me what is in a directory¶
You would like to know more about the content of a directory. ls is the program that gives you a lot of information.
- ls lists all files and directories
- ls -l shows a more detailed list of the files/directories with time, user access rights
- ls -a also shows hidden files
- ls -al you can combine the different options
- ls -1 shows only the file names
cd ~/demo
ls -l
total 4
-rw-rw-r-- 1 user user 0 Dec 26 16:23 hello.txt
-rw-rw-r-- 1 user user 255 Dec 26 16:24 history.txt
Copy files and directories¶
You can copy files from one location to another.
Copy a file to a new file
cp hello.txt hello_again.txt
Copy a file to another directory
cp hello.txt /home/user/
Copy a whole directory to a new location (-R recursive)
cp -R /home/user/demo /tmp
Who is sudo?¶
With sudo you can do things that you are normally not allowed to. sudo runs commands with the rights of the superuser also known as root With sudo you can i.e. install more software, administrate services, change access rights and more fun. You will see the use of sudo in some of the following commands.
Search and install programs¶
Show information about programs.
apt show postgis
Search for programs
apt search postgis
Install programs
sudo apt-get install sl
You will love the program sl. Run the new program with sl see also apt show sl.
Services¶
Some programms run as services like PostgreSQL, tomcat or Apache Webserver. You can start or stop the services.
Restart your Apache Service
sudo service apache2 restart
sudo service apache2 --help
sudo service apache2 status
How to edit files¶
You can either edit files in the terminal or open them with an external program like Geany.
In the terminal window you can use the vim editor (Vi IMproved). vim is very powerful and has many options.
See also
Open a file with vim:
vim /home/user/demo/hello.txt
- press i to switch to the input mode
- ESC leaves the input mode
- :w saves your changes
- :wq saves your changes and closes the file
- :q closes the file
- :q! closes the file without saving
Owner and access rights¶
Access rights define whether a user or group or others have access to a file and what sort of access is given. You can have read, write or excecute access.
Directories or files have an owner and a group definition. By default the creator of a file/directory is the owner. But this definition can be changed. You will learn this in the next section.
You can show the owner and group via ls -l
cd /home/user/demo
ls -l
-rw-rw-r-- 1 user user 122 Dec 26 16:11 history.txt
- the initial character can be - for a file or d for directory
- user is defined as the owner and the group
Access rights are listed at the beginning of the row:
- r read
- w write
- x execute
- first 3 letters for the owner
- then next 3 letters for the group
- followed by the last 3 letters for others
Change the owner with chown¶
sudo chown -R user:www-data /var/www/html/TBD
- first pass the user then the group - like user:www-data
- -R recursive
Change access rights with chmod¶
sudo chmod -R 777 /var/www/html/TBD
- 777 everyone can do everything
- -R recursive
- number: owner (u)
- number: group (g)
- number: other (o)
- 4 read
- 2 write
- 1 execute
- 660 - owner and group are allowed to read and write, other have no rights
- 744 - owner can do everything, group and others can only read
or use it like this
sudo chmod -R u+rwx /var/www/html/TBD
- u = user
- g = group
- o = other
- a = all
- +/- right: r = read / w = write / x = execute
Things to try¶
Here are other commands you may try.
- grep - search for a pattern in a text
- history | grep cd
- rm - remove a file
- rmdir - remove an empty directory
- mv - rename/move
- head - show the beginning of a file
- tail - show the end of a file
- find - search for files in a directory hierarchy
- locate - find files by name
What next?¶
You have learned some important commands and information to work with the command line. Hopefully you have discovered how powerful the command line is.
