OSGeo-Live Quickstart
This Quick Start describes how to start OSGeo-Live from a DVD or USB.
System Requirements
Your computer should have at least:
  • RAM: 1 GB.
  • CPU: 1 GHz i686 or compatible (Intel/AMD)
  • Hard Disk:
  • None required if running directly from the DVD
  • 10 GB if you wish to install the operating system.
  • Mouse: a 3-button mouse is useful, especially for Mac trackpad users.
Run:
Source an OSGeo-Live DVD, ISO available from: http://download.osgeo.org/livedvd Put the DVD into your computer’s CD drive, then reboot your computer.
If your computer is set to boot from CD (as is often the case) you should boot up into an Xubuntu system, with Geospatial applications installed. Otherwise you’ll have to adjust the BIOS boot settings or press the boot menu button just after powering-up.
boot select
When you see the above screen, you can press the spacebar to get to the special boot-up options menu. In most cases you won’t have to do that.
boot
Sit back while the system boots up.
boot select
Try the many applications from the Geospatial menu.
Getting started with the Xfce desktop: (an online work in progress)
http://docs.xfce.org/start
Getting started with the Ubuntu operating system: (a nice PDF e-book)
/usr/local/share/doc/Getting_Started_with_Ubuntu_12.04.pdf
Further online help with the Ubuntu operating system: (n.b. we use the traditional Xfce desktop interface, not the tablet-like Unity desktop interface)
https://help.ubuntu.com/12.04/
https://help.ubuntu.com/12.04/serverguide/C/
https://help.ubuntu.com/11.04/ubuntu-classic/gnome-classic-index/C/
Copyright & Disclaimer
