project logo
rasdaman Quickstart
rasdaman is a raster server allowing queries on n-D raster data stored in a standard relational database.
This Quick Start describes how to try out queries on a sandbox of raster objects. Before trying these examples, the rasdaman server has to be started (Geospatial ‣ Databases ‣ Rasdaman ‣ Start Rasdaman Server).
Exploring the 1-D to 4-D examples
  • You can access the local rasdaman demonstrator to explore various demo data sets. The small ones are part of OSGeo-Live, those utilizing larger sets forward directly to the Earthlook site (requires active network connection).
Running queries locally
  • Open a console and open the sample database installed locally
  • use the rasql utility to send queries and receive results, for example:
    $ rasql -q "select png((char)(c.red / (c.red + c.green) - c.green / (c.red + c.green)) > 0.6 * 255) from rgb AS c" --out file
  • use your favorite image inspection tool to open the file generated.
Create your own database
  • Open a console
  • Download and install rasdaman and its prerequisites
  • run the demo ingestion script:
    $ install_demo.sh
    $ rasql -q "select png( NIR ) from NIR" --out file
Things to Try:
Here are some additional challenges for you to try:
Copyright & Disclaimer
