project logo
MapTiler Quickstart
MapTiler provides a simple way of creating a set of tiles from any georeferenced map image. The tiles can then be presented as a as a georeferenced map overlay on a web server. It follows the Open Source Geospatial Foundation’s (OSGeo’s) Tile Map Service (TMS) specification.
  • Input options: Any georeferenced image file, eg. a TIFF, JPEG from ArcGIS, QGIS.
  • Output options: A set of directories with tiled images which can be copied to a web server for presentation as a georeferenced overlay. View examples.
  • Strengths: MapTiler is simple, free, open-source software, with an easy wizard, described below, to guide through the options.
MapTiler takes advantage of the fact that Google Maps , Microsoft Bing , Yahoo Maps , and other online mapping providers including OpenStreetMap use the same projection and tiling profile and the tiles are therefore compatible. The Tiles à la Google Maps page describes and illustrates this. MapTiler prepares tiles using this specification as an easy and quick way of preparing a georeferenced map in a mashup web page.
Start MapTiler
  1. Download MapTiler to your it on your computer or start it directly from this LiveDVD.
  2. Select the Tile Profile. Choose Google Maps Compatible (Spherical Mercator) for standard web publishing. Choose Google Earth (KML SuperOverlay) if you also want to generate a KML file for use in Google Earth. Click Continue.
../../_images/maptiler13.jpg
  1. Choose the Source Data Files. Browse to select the raster image you want to tile. It is also possible to select a NODATA colour that will appear as transparent in the resulting image. Click Continue.
../../_images/maptiler23.jpg
  1. Specify the Spatial Reference System / Coordinate System of the image. Specify the id-number from the EPSG/ESRI database. If you have maps from UK for example the transformation should include the EPSG:27700 with TOWGS84 parameter. Click Continue.
../../_images/maptiler33.jpg
  1. Specify details about the Tile Pyramid. The default settings for zoom levels and file format are often best. Click Continue.
../../_images/maptiler43.jpg
  1. Specify details about the Destination folder and Addresses / URLs for the tileset. If you do not know these, they can be added into the default googlemaps.html and openlayers.html files after tile generation. Click Continue.
../../_images/maptiler53.jpg
  1. Tick the Viewers that should be generated. By default, a googlemaps.html and openlayers.html file are generated. You can also choose to generate a KML SuperOverlay file for Google Earth. Click Continue.
../../_images/maptiler63.jpg
  1. Specify the Details for generating the Viewers, such as the title, copyright notice, and API keys. If you do not know these, they can be added into the default googlemaps.html / openlayers.html files after tile generation. Click Continue.
../../_images/maptiler73.jpg
  1. Click Render to start rendering the image. When complete, MapTiler provides a link to the finished tileset. Open the googlemaps.html or openlayers.html files in a web browser to view the tileset as an overlay on the live online map. To present this on the web, just copy the entire tileset and all subdirectories to a web server, and edit the googlemaps.html or openlayers.html files as required.
Using gdal2tiles to create a MBTiles database
MapTiler is essentially a GUI frontend to the gdal2tiles.py script. An updated version of gdal2tiles.py is also present on the Live disc. The resulting tile trees created by these software can be used with the mb-util program to create an mbtiles database, for use with smartphone software like Geopaparazzi.
To create an MBTiles SQLite database from the newly created tile tree, open a terminal, then
cp data/raster/bluemarble.tif .
maptiler    # (select /home/user/bluemarble.tif for input, JPEG as format)
mb-util --scheme=tms --image_format=jpg bluemarble bluemarble.mbtiles
qgis bluemarble.mbtiles
See gdal2tiles.py –help and mb-util –help for additional information on running these tools.
Copyright & Disclaimer
