GeoNetwork Quickstart¶
GeoNetwork is a catalog application to manage spatially referenced resources. It provides powerful metadata editing and search functions as well as an interactive web map viewer. It is currently used in numerous Spatial Data Infrastructure initiatives across the world.
Apart from how to start the catalog, this Quick Start describes: * some of the different ways you can search for spatial data * how to download and display data from the search results
Contents
Starting the catalog¶
After going through the installer steps, simply go to bin folder and click on start.bat (on windows) or start.sh (on linux).
Go to the home page at http://localhost:8880/geonetwork. Your first view
should look like this:
Signing in and load templates¶
Click the sign in to connect as administrator. The default account is
username admin with password admin.
Once connected, the top toolbar should provide a link to the admin console
and your login details.
Go to the admin console and click on metadata and templates:
Choose all standards and click load samples and then load templates in
order to load examples:
Go back to the search page to see examples:
Searching information¶
The search form provides different ways for search:
- a full text search box providing suggestions
- facets which defines groups that you can easily click on to browse the content of the catalog
- spatial filtering to choose information in specific areas
- advanced search
Discovering information¶
Search results present main information about each resources: title, abstract, categories, status, overview and links.
Clicking the record will provide more in depth details about the resources:
- Download and links
 - About the resource
 - Technical information
 - Metadata details
To get more information, switch the advanced view mode. To update the record, click the edit button.
From the results or the record view, you can easily add WMS layers referenced in a metadata record on the map. With the map, you can visualize your data, choose your background maps, query objects, display on a 3D globe and more ...
What Next?¶
Continue reading the documentation: http://geonetwork-opensource.org/docs.html
