Getting started with OSGeoLive¶
This Quick Start describes how to start OSGeoLive from a DVD or USB.
System Requirements¶
Your computer should have at least:
RAM: minimum 2 GB (4 GB recommended).
CPU: 1 GHz 64 bit.
Hard Disk:
None required if running directly from the DVD
20 GB if you wish to install the operating system.
Mouse: a 3-button mouse is useful, especially for Mac trackpad users.
Run:¶
Source an OSGeoLive DVD, ISO available from: [Download] Put the DVD into your computer’s CD drive, then reboot your computer.
If your computer is set to boot from CD (as is often the case) you should boot up into a Lubuntu system, with Geospatial applications installed. Otherwise you’ll have to adjust the BIOS boot settings or press the boot menu button just after powering-up.
Sit back while the system boots up.
Try the many applications from the menu.
See Also:¶
- Getting started with Lubuntu and the LXQt desktop (which is used by OSGeoLive):
- Getting started with the Ubuntu operating system:
