project logo
KDE-edu Marble Quickstart
Getting Started
  • Click on the desktop icon
  • If you have used Google Earth before you should be able to figure this program out without much difficulty.
  • In the Settings menu select full-screen mode
  • Explore ...
  • Click on a city name (cursor becomes a pointing hand), within the info center select the Wikipedia tab and read about the place
  • In the bottom-left corner of the program window there is a subtle tab called “Map View”. Click on it.
  • Select another map (e.g. ‘Precipitation (July)’)
  • Explore some more ...
See the Marble homepage for more help.
Copyright & Disclaimer
