Open Source Software Image Map (OOSIM) is a high performance engine for remote sensing, image processing, geographical information system and photogrammetry.
- View raster images with imagelinker
 - Run ossimPlanet
Start Imagelinker from its icon from the directory “Spatial Tools” on the desktop
Select the project file, using File ‣ Open Project ‣ /home/user/ossim/landsatrgb.prj
Go to the menu bar ‣ window ‣ tile
Select an image window ‣ select the pan icon ‣ click on the image ‣ press the button “propagate”
Verify you see a 3 gray satelite images.
For the full tutorial see this blog article.
Note
To turn off the daylight auto-shading, un-check File ‣ Preferences ‣ Environment ‣ Enable Ephemeris
Ossim Tutorials
Follow the tutorials to learn more about Ossim.
Documentation on DVD
See also the included documentation on this DVD.
