pgRouting logo
pgRouting Quickstart
pgRouting is an extension and adds routing and other network analysis functionality to PostGIS/PostgreSQL databases.
This Quick Start describes how to open a database with the command line and run a basic shortest path query with the sample test data.
Running pgRouting
  • Open a Applications ‣ Accessories ‣ Terminal window and connect to the pgrouting database:
psql -U user pgrouting
  • Type \d will list you all available tables:
                List of relations
 Schema |        Name         |   Type   | Owner
 public | classes             | table    | user
 public | geography_columns   | view     | user
 public | geometry_columns    | view     | user
 public | nodes               | table    | user
 public | raster_columns      | view     | user
 public | raster_overviews    | view     | user
 public | relation_ways       | table    | user
 public | relations           | table    | user
 public | spatial_ref_sys     | table    | user
 public | types               | table    | user
 public | vertices_tmp        | table    | user
 public | vertices_tmp_id_seq | sequence | user
 public | way_tag             | table    | user
 public | ways                | table    | user
(14 rows)
  • Run the Dijkstra shortest path function:
SELECT seq, id1 AS node, id2 AS edge, cost
        FROM pgr_dijkstra('
                SELECT gid::int as id, source::int, target::int,
                        length::float8 as cost FROM ways',
                100, 600, false, false
 seq | node | edge  |        cost
   0 |  100 |   115 |  0.0605959823538948
   1 |   99 |  2972 |   0.197600739218643
   2 | 2151 |  3783 |  0.0139212050887606
  52 |  599 |   732 |  0.0390125147117973
  53 |  600 |    -1 |                   0
(54 rows)
  • To output the route geometry, link the result with the road geometries:
SELECT seq, id2 AS edge, rpad(b.the_geom,60,' ') AS "the_geom (truncated)"
        FROM pgr_dijkstra('
        ) a INNER JOIN ways b ON (a.id2 = b.gid) ORDER BY seq;
 seq | edge  |                     the_geom (truncated)
   0 |   115 | 0102000020E610000002000000012D0208C4B0F2BFBD2DA237267A4A40E5
   1 |  2972 | 0102000020E610000002000000622B0DA1EFB3F2BF65236B685E7A4A4001
   2 |  3783 | 0102000020E610000002000000BD4571D8C7B4F2BFB2648EE55D7A4A4062
  52 |   732 | 0102000020E6100000020000006B48DC63E903F3BF84CCDFCECF7B4A40E9
(53 rows)
  • With \q command leave the PostgreSQL shell.
What next?
Copyright & Disclaimer
